Another bad manifold
Royse
This one on an 8N I started on today.
I'm hoping for the best on the block.
[b:8777a5c8cb][i:8777a5c8cb]
I'm not thinkin' that will buff right out.
Good luck on the block surface.!!!
That has been leaking for awhile!!!???
GB
[/i:8777a5c8cb][/b:8777a5c8cb]
(quoted from post at 16:30:32 04/07/17) This one on an 8N I started on today.
I used a product called quiksteel a while on a pitted out #4 exhaust port and it worked real well
Pleasant surprise.
And here's the reason a running 8N was cheap. Clutch is stuck tight.
nice. since the block is intact, u should be able to just wrap some gorilla tape around the end of the manifold :idea:
but i don't think that will help the clutch, you're on your own there :)
LOL manifold is already in the scrap pile. They're not that expensive.
Engine actually runs very well. I'm going to put it in my 8N so it's
not down while I rebuild my engine, then I'll probably sell this one.
I have a third side mount that is going into this tractor so I can
see how it runs. This 8N will then get sold pretty cheap.
