Bruce (VA)
" do you know if it is normal that I can turn flywheel through the peep with a prybar, and the distributor rotor does not move? "
Nope, that's not normal. But you do need to move the flywheel more than a few teeth. And make sure the rotor is indeed firmly attached to the shaft. No need to do any more work on the tractor until you resolve that issue.
75 Tips
75 Tips
