cabinkiotio
good morning all. Just returned from my cabin after working on my 51 8n, It seemed to be starving for fuel so I drained the fuel tank and removed the fuel bowl assembly. everything looked pretty clean and put it back. My brother in law installed a inline fuel filter (see through) and there was only a trickle of fuel going into it. As soon as I loosened the clamp the air that was in the filter could escape and it filled right up with fuel. I guess it was air locked and couldn't get enough fuel to run under load. I am going to remove the hood to remove the radiator, both radiator side supports that are attached to the radiator are broken loose. Was wondering if I should get it repaired or replace the radiator while it is apart. I think this is the last repair on this tractor,i hope.
