Greetings - I've just purchased an overhauled 2N with an 8N engine. Everything runs and looks great with one small exception. There is a fuel leak on the intake line connector at the bowl. The previous owner pointed this out and mentioned that he couldn't get it to stop so he always just shut the gas off after operating. I'm about to take it apart and check for any obvious issue like a bent flange or cross threading - but I'm wondering if this is common and if I should just replace that fuel line to make the fix easier. Gas leaking in any amount whatsoever just can't be a good thing!
