3 point adjustment?
kev518n
My 3 Point won't start coming up until the lever is a good 3/4 of the way up the travel. Is there any kind of adjustment for them. Seems like it still want to keep lifting when it gets to the top also.
Is this a 9N, 2N, or 8N? If a 9 or 2N this is normal. There is no position control on a 9 or 2N. You can add it with Zane
Sherman's 'Zane Thang'. If this is an 8N are you in draft mode or position mode? If in draft mode this is normal.
(quoted from post at 08:28:12 03/28/17) Is this a 9N, 2N, or 8N? If a 9 or 2N this is normal. There is no position control on a 9 or 2N. You can add it with Zane
51 8n ford. Lever is up in position mode
Soundguy is correct. Zane Sherman sells a jig to adjust the lift and it includes a cam pin and good instructions. You have to
remove the top cover. You will need a gasket set in addition to the pin. You can adjust the lift without Zane's jig by
following the FO4 manual but Zane's jig makes it much easier.
(quoted from post at 11:08:26 03/28/17) Soundguy is correct. Zane Sherman sells a jig to adjust the lift and it includes a cam pin and good instructions. You have to
ok i will check out my manual. thanks
If it is still loading the engine when it gets to the top of it's travel the control rod is bent badly and the piston can't push the control rod back
to put the pump in neutral.
(quoted from post at 19:02:24 04/01/17) If it is still loading the engine when it gets to the top of it's travel the control rod is bent badly and the piston can't push the control rod back
i dont think it ever goes in nuetral. it does start lifting at the bottom of the travel now that i have the live hydraulics hooked up. but never does go in nuetral
