Ruttdigger
New User
So in a previous post I was having problems with my 8n not starting. I replaced the starter solenoid and the carb and she started right up. Brush hogged my yard and started in the overgrown field behind my
house (probably 2 acres total work and a few hours work) and she just died. No warning, not a stumble, not even like I hit something that put too much load on the tractor. Just sputtered 2 times and died.
Refused to start after that.
I thought the battery was the culprit and I replaced the very old battery with a new one. Still no start.
Starter motor sounds strong. Gas seems to be getting to the carb. This tractor was converted to a 12 volt side alternator setup by someone else. I am having a hard time figuring out things on it after the
conversion and seems like I am getting some gremlins in the electrical.
Any advise on field trouble shooting? Maybe needs spark plugs but it is just weird that it was all working fine and honestly like new after the starter solenoid and carb replacement then just died.
Oh and I did check the gas. there was a full tank.
