SteveRussell
8N , 1952 model, after 263xxx. Side Mount. The tractor is 150 miles away in the country so don't get to stay with it often. Problem, since Nov last will hardly run under in gear. Have had the carb rebuilt by professional. It seemed to be slow on the drain test. It would crank and idle, for seconds to a minute at a time When it last ran in January. Recently used fully charged battery. Cleaned points with a piece of brown kraft paper, it started and ran better, but replaced them with a new NAPA points and rotor. . The fuel delivery was still suspect in volume, drained and replaced the entire Fuel Sediment Bowl Assembly. Found the filter screen was missing from the top of original one when pulled. (I already had the assembly on hand as a spare). The spark plugs were replaced in NOV 2016, and hasn't seen much use since then. It will crank and run and idle for as long as you want, now, but put it in gear and let off the clutch and it stumbles and stalls out.
Did I get it out of time ?, should I just put in fresh spark plugs? It has been 70-80 degrees in this part of Texas lately so don't think it is the "cold"
Will we going back up next week and need to work on it then,
your comments & suggestions are appreciated.
