Jim in Western MI
The "new to me" 8N front mount I've been converting to 12v, which typically mission-crept into other smaller repairs, has undergone its oil change. Previous owner had recently changed it, so it wasn't first on my list. But the drain plug was mostly rounded off and a bear to get out, even with the jack-and-wood device. But it was done. Old plug had no screen so ordered one from one of the vendors often mentioned here. The new plug's screen is poorly soldered, loose wire ends that are brittle and break off, besides being crunched in the shipment. I wonder if the screen is really helpful. Searching the archives there are opinions that the screen catches big loose things, that it sometimes causes the oil pick up tube to become loose due to vibration, and that it supports the tube to prevent it coming loose. Many opinions..., mostly several years old from writers not now posting. My opinion is that there are bigger problems happening if the screen is catching things, and I don't like the new one with friable loose wire ends that are small enough to get sucked into the oil tube. I would appreciate other opinions and experiences.
