nathanialbumpo
OK, I'm changing the governor on my 1943 9N which relies on splash oil for lubrication, the new one has a fitting for a oil line just like the 2 lever 8N does. The oil is supplied by a fitting on the bottom of the filter. The problem is on the 9n there already is a tube there that goes in the side of the block just below the filter.
I can tee off of the filter or the block, but I was wonder if that tubes was just some kind of a pressure relief or does it lube something??
Thanks
Ed
Thanks
Ed
