The 8n I am working on is giving me a fit. Changed the oil a few weeks back and it ran great while letting
it warm up. After adding oil and started back up it ran a couple minutes and started skipping bad and cut
off. Gas started leaking out of the bottom of the carburetor. I worked on the carb and could never get it
to stop leaking so bought a new one and installed today. The tractor started up and run less than a minute
and started skipping and smoking blackish smoke this time and before it was blue. Removed spark plugs and
they had some sludge on them and black I cleaned them and the tractor started up and less than a minute it
started skipping. I can clean them and it will run only a couple minutes and then back black again. The
sludge was only on them the first time. After I removed them the first time a turned the engine over a
couple times and it blower a little stuff out. Not sure were given here any help would be appreciated
thanks
thanks
