Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
reserve
Dune Country
03-19-2017 15:45:11
Wouldn't it be wise to open the sediment bowl petcock all of the way and run the tractor every now and then to keep the crud from plugging it up?
Dell (WA)
03-19-2017 17:11:08
 Re: reserve in reply to Dune Country, 03-19-2017 15:45:11
DC........yer glass filter bowl is one of 3-filter schemes to keep from cloggin-up yer carbie. Recommend NO-MORE than 2-turns to run yer tractor. Otherwize you will be suckin' crud and stuff from the bottom of the 10-gal tank. Iff'n you like cleaning and rebuilding carbies, go ahead suck the crud. Me? I just keep the gastank filled. Simple, eh?.......the amazed Dell
HFJ
03-19-2017 16:37:42
i hope u have better luck than i have had. my N came with a plugged reserve, and when i replaced the sediment bowl assembly, the new reserve was already restricted on the first attempt to start the tractor to the point of not allowing it to run longer than about 5 seconds. it wasn't zero flow, but it was not enough to be useful.
steve19438
03-19-2017 16:07:39
since I only have two acres and am never far from a can of fuel I usually open the valve till it stops.
Jerry9N
03-19-2017 16:04:01
I do it occasionally, I don't think that it will keep it from clogging, but I don't want water to build up there. There is a theory that condensation can form inside the tank if you don't keep it filled, and that over time this would collect in the bottom of the tank. I've never had water in my tank, so I can't say the theory is valid, but it doesn't hurt to open it up. If it does clog, then the tank is closer to empty so that I can pull the shutoff valve and clean it.
Jerry
