8n front pulley
Try an 1 5/16" open end wrench. Might have enough room to get it
off. Although it may be easier to pull the axle carrier
Kirk
Well, can you support the hood, radiator, dog legs,
etc once the axle support is removed?
I guess you can use straps with an overhead or
engine hoist to hold it all while the work is done.
Empty the gas tank for lighter weight.
Greg
(quoted from post at 17:17:09 03/13/17) Are you going after the front seal ?? I'm curious as it looks like I might need to do mine.
No I am going after the pulley itself. it wobbles. trying to figure out how much work I want to do! Did not notice it with a generator but with alternator, it makes the alt shake a bit.
(quoted from post at 12:14:48 03/14/17)
Very common to wobble for the original tin pulleys. Many run this way ok.
