How Do I Get The Adjuster Out Of Sector
KCTractors
Location
Central Wi
Working on a later style of steering-box on a 8N. I have the sector out of the box and I want to get the cover off the sector. The adjuster unscrewed flush with the cover,but that's is far as it will go. I didn't want to screw anything up till I asked somebody how it does come apart. It should be easier to time the gears with the cover off.
Thanks, Ultradog MN, the threads must be bugged up a little bit on the end. The screw goes in good till it gets flush with the cover. I'll cut the slot just a little deeper on the screw and use a wrench on the screw-driver. Now I know that the screw has to come out.
