Zenith carb
(quoted from post at 15:13:19 03/10/17)
I have the carb, but making sure it will fit!!! Got a deal on it at an auction. They said it was for an 8n...
b:0527839fd9][i:0527839fd9]
Ron;
The right Zenith carb, should have an alum. part tag on one of the top screws, that has the Zenith part# 13876 stamped into it.
Still need a picture of it, to make sure it IS actually a Zenith carb!!!!
Gary[/i:0527839fd9][/b:0527839fd9]
(quoted from post at 22:47:31 03/10/17)
b:31d528237c][i:31d528237c]
Ron;
Gary[/i:31d528237c][/b:31d528237c]
It looks like a Zenith, Mine has an alum. tag stamped: 3 98, 13876, B3NN A. The distance between the mounting studs should measure 2.25" (same as an 8N) and the bore is 1.0". The bore on an OEM 8N carb measures 1.063".
Looks like a Zenith from what I can tell from the top view.
They're good carbs, just hard to find a complete kit for a rebuild.
You will either have to mic it all out and order the parts you need
separately, buy the generic kit and hope for the best, or find a
source that I have not found yet. If you find that source I would
sure be interested in knowing who/where it is.
(quoted from post at 22:13:19 03/10/17)
Finally figured this out, I think...
That looks like the same carb that is on my 9n. A lot of carb kits
for Case model SC with Zenith 9667 carb come with gaskets for
that carb. The needle,seat and I think float are the same.
Try McDonald carb.com for parts.
