Question on timing.... installed the new distributor tonight, static timed at 28 degrees then timed with light. At 29 degrees per the light at wide open, I get 21 or 22 at idle.
Still have a slight miss with gas hiccuped out the exhaust. If I set the distributor to 8 degrees at a idle, the miss goes away but I only get about 23 degrees at wide open.
The manual says that a "bad advance governor is indicated" if I can't get between 10 and 0 at idle. But everything is new.
What do I look for? Set it for wide open and have to live with idle advance? Really trying to smooth out the miss but not lose power at wide open.
