8n hydraulic lift question
Tnhuckabee94
New User
I have a 49 8n. Was told the hydraulic pump was rebuilt shortly before I bought it.(2 years ago). Although the hydraulics lift and lower just fine, I cannot seem to be able to keep any type of attachment to stay steady. It either drafts lower or upward in time. Any suggestions would be appreciated.
The pump was rebuilt and apparently is providing enough
pressure to lift Ok.
What was done to the top cover, linkage and adjustments?
Maybe they need to be looked at too. They wear over time.
Pump may be fine, but lift cover may need adjustment.
Question: Does your 3pt lever move while the lift is drifting? if yes, then check your friction disc.
Could be that the cam follower pin is worn completely off. When that happens the lift will act like it is in "draft" mode.
If that is the case you could just add a "Zane Thang" position control device and not have to take the cover off to have position again.
Zane
ZANES LIFT STUFF
