Replacement parts for Dearborn 10-156 plow?
10kpharo
Hi, all. I found a Dearborn model 10-156 14" 2 bottom 'Economy' plow for sale not too far from me. One blade share needs to be replaced. Can anyone point me to a source of replacement parts for these plows? I don't want to buy the plow unless I know I can get what I need to make it operational again. The share is held on with three bolts. As you can see, the plow needs some work.
Thanks.
julian
Tyler Bucheit, ph.# 573-768-4092 or mrbtractors.com (website) or [email protected] (email)
Ferguson/Sherman was the distribution company. The plows were made by Ford in the Rouge plant until around 1942 or so. The front coulter can usually be found used and the ones from the Dearborn prior modfel plows also interchange with the Ferguson coulters. For new plow shares Steve Rhea at ploworx is producing them new. Just contact him.http://www.ploworx.com/
Try OSMUNDSON -see link below. Many TSC stores stock shares and landsides for the FORD 14" Plows too. Alos, SWEIGARD BROS in Halifax, PA, Scott Deppen so google him. You'll need the original part number to cross reference.
Tim
Implement Parts
