no control of 3 point position
kevsdodge
Looking for help. My 3 point arms are either up or they are down. If the draft lever is off the bottom the arm go all the way up. Putting a blade on the unit does
not help. should be able to lift the blade 2 inch off the ground but on this 8N. Where would the problem be?
Kev........look under yer right knee. That ain't a "flush" handle, ittza position-draft (plowing) control selector handle. Owe bouy, (memory lock-up) UP fer position and HORIZONTAL fer plowing. .........HTH, Dell, yer self-appointed sparkie-meister and re-memory guy
I was going to ask that obvious question but I saw that he had 230 posts here on the forum and figured that he surely must know about that handle.
But I guess that can't be taken for granted.
I would like to take your reply and run with it but as a person how would no this I can not. I have Ferguson TO20, Ford 860, MM Z, Farmall BN and Super M, Case SC and VAC's but
no 8N's Buddy asked me the question and I had no clue so I proposed the question here as my involvement in the Case and Farmall forums have been get get help when I get stuck.
Any chance for a photo to show him this lever as my two unit close to the 8N do not have.
Here you go.
serveimage
(quoted from post at 11:12:14 03/02/17) Thank you very much the photo has been shown to my coworker and he will address that today.
thanks again
The lever is in position control mode, down is for draft control mode.
