Clam digger
I have a 1954 NAA with a few Implements. My problem is my over running clutch does not fit on my PTO shaft very tight. I still have the original PTO shaft on the tractor and don't want to change it because i have a cord wood saw and need it for the pulley. When i use it with my wood chipper it seems to be taking some of the metal off either the tractor or the over running clutch because it fit lose on the pto shaft. I haven't used on the brush hog in a while so not sure if it will do the same thing . My question is should the over running clutch fit on tight or is there a little play. It's not that old Thanks
