Hydraulic pump for Dearborn loader
I had a problem with my front pump stinger shaft that drives the pump for Dearborn 19-22 FEL. Result is damaged input shaft seal, and all of my fluid fell out. Was working well before I fouled it up.
Only markings are Eaton 26000, which isn't terribly specific. Where to find parts? Online or local pump repair shop?
BTW, split my 8N Saturday to disengage broken starter drive gear from flywheel. Ring gear in good shape, replaced all clutch parts, starter drive. In and out in four hours. First time split, two old guys (66 & 71), and a kid (48). It went well, thanks to input from y'all here. Thank you!!
(quoted from post at 15:35:12 02/21/17) I had a problem with my front pump stinger shaft that drives the pump for Dearborn 19-22 FEL. Result is damaged input shaft seal, and all of my fluid fell out. Was working well before I fouled it up.
The 2600 Series from Eaton is a common pump and comes in a number of different displacements. What exactly is wrong and what are you trying to fix?
TOH
The input shaft seal was damaged when the flex coupler slid in on
the shaft and made contact with the seal. Big leak.
Pump worked well prior to seal damage. No other leaks noted.
