Rick B 8N WA
I had a problem with my front pump stinger shaft that drives the pump for Dearborn 19-22 FEL. Result is damaged input shaft seal, and all of my fluid fell out. Was working well before I fouled it up.
Only markings are Eaton 26000, which isn't terribly specific. Where to find parts? Online or local pump repair shop?
BTW, split my 8N Saturday to disengage broken starter drive gear from flywheel. Ring gear in good shape, replaced all clutch parts, starter drive. In and out in four hours. First time split, two old guys (66 & 71), and a kid (48). It went well, thanks to input from y'all here. Thank you!!
