Hobo,NC
- Location
- Sanford, NC
Normal I put the starter in the press to get the starter drive pin out. I had one this week the pin was stuck so I had to come up with a way to press the drive and hold it while I beat the pin out, this one was a bugger. Pix suck but I thing you will get the I.D.
All thread a few nuts and some steel. leave the all thread long and clap it in a vice
The pin was stuck so bad I had to make a plate with a hole in it so I could drive the pin out
Used what I had on hand quick to hold the drive while I pressed it down to get the pin in will cut up a had full if washers for the next one.
http://i102.photobucket.com/albums/m103/hobo1301/8N STARTER TOOL 010_zpsaswvyhwt.jpg
