G6 at Snook, TX
I posted this in tool talk, but I wanted to cast a wider net.
I have a Lincoln Weldanpower from about 1987. It has a Briggs 16hp single cylinder motor on it and after about an hour of running, it begins to surge. We thought it a fuel issue, but that has been ruled out. It was switched from points to EI at some point. Would a failing EI cause a surge issue after about an hour of run time while under intermittent load? What other electrical things can we check? Would the ignition switch go bad in this manner?
Thanks
Thanks
