Hello all,
I've read these forums for quite some time and now need some guidance. I bought a 47' 8N from a widow and am in the process of making repairs. Unfortunately her late husband was a bit of a "cobble jockey" and many things are sketchy at best. I have to replace the right front spindle and bushings. I have the spindle and bushings removed but need to know about the seals. There weren't any seals on the top or bottom of the spindle and the parts listings show seals for both. It appears the upper seal is felt but the lower seal is the quandary. Is there a lower seal and if so is it installed below the lower thrust bearing? Thanks in advance for your input and advice.
