8N Oil Pan Drain Plug
Audioguy
Drained the oil for the first time since I've owned this rascal and noticed there is no screen, don't feel anything inside the pan. Just replace the assembly and move on?
See if the pickup tube cup is centered over the drain bung hole, and not loose.
If yes, yeah.. Get a new plug with screen and gasket, clean gasket flange on pan, etc.
Save the old cap... Never know when you might need it. :)
Mine was like that on the first oil change,48 8n, I looked around and felt in the pan as far as I could.
Didn't find anything, just put in the new plug and strainer. Good to go.
Well... I'm having a really good day. Checked under the tractor this evening and the oil pickup is centered over the
drain hole, and it is not at all loose. Parts on the way. Thanks a bunch for the advise.
