pinion removal
I have my new rear housing cleaned up and painted and ready to go. I am using the ring and pinion from my old housing. My question is do I need a puller to remove the pinion assembly or does it just pull right out after I remove the 6 bolts that hold it into the housing
(quoted from post at 06:38:09 02/05/17) I have my new rear housing cleaned up and painted and ready to go. I am using the ring and pinion from my old housing. My question is do I need a puller to remove the pinion assembly or does it just pull right out after I remove the 6 bolts that hold it into the housing
You may have to thread a bolt in the end of the pinion and use a slide puller to get it out.
http://www.northerntool.com/shop/to...xAXd1eDq1MxCtkuNHh6XyszzORI6iMi54_hoCyRXw_wcB
(quoted from post at 20:26:14 02/04/17) I have that pulled I just didn't know if it would come right out or did I need to use a puller
I have 3 - 8N's that I am SLOWLY getting overhauled . Two of them had chipped pinions . I had 4 extra rear ends. I ground off the rivet heads on 2 to remove the splash shields and bearings . I have 2 more that still have the pinion bearings . I kind of like "If it ain't broke tear it apart to see how it works and hope you don't break it " philosophy . I don't remember why I did not want to drive the bearings out of the front .
After reading one of your posts about the drive screw I reached in yesterday and I could feel the other end sticking out the back side . Hopefully today I find time to see if I can tap the screw / rivet out backwards .
I have an extra drive shaft coupler that connects the transmission to the pinion . I plan on cutting the ends off and welding an old 3/8" drive socket to the ends so I can use that with the inch pound torque wrench to set my pre load . The out put splines on the trans are the same size as the input splines from the clutch so that one socket will check the trans .
John Smith8N
Long Time User
PostPosted: Sun Jan 29, 2017 11:58 am Post subject: Re: pinion gear question Reply to specific post Reply with quote
Skip Burney wrote:
(quoted from post at 04:49:45 01/29/17) I got mine apart and cleaned up today, those rivets are actually drive screws. You can grind the head off replace the bearing and redrill the holes and put the splash guard back with 2 new drive screws
The bearing bore is a straight thru hole. Once the pinion is out you can knock the bearing out in that direction to replace it. No need to remove the oil trough and drive screws.
(quoted from post at 10:49:06 02/05/17)
John Smith8N
I remember reading that , of course after I had ground off the heads . I don't remember why I wanted the bearing to go out the back and not the front ? I think ( from memory ) the bearing is tight and the splash guard restricts the surface area available to drive against and from the front you can get a long pipe / driver straight in and take a long swing with the hammer where from the back space is very limited .
I went to the shop and was able to easily drive out the rivets from the backside and remove the splash guard . I did not see any splines so I will assume it is a rivet . Mic'd it at .2570 - .2580 x 1.25" After removing the splash guard I lightly tapped the rivet back in the hole and did not feel that it was tight enough to reuse . A 1/4 x 1-1/2 " bolt would work but is just a little loose . A 2" long bolt would also work as neither end is any where close to the ring gear .
I had difficulties trying to remove the bearing from the back without removing the guard . Space is limited and I only wanted to apply force to the outside edge of the bearing and not stress the inner cone or roller pins . Those bearings are about $70 . I even wedged in a small hydraulic jack and small steel block from the back with no luck . Maybe it is just me , but tapping it out from front to back is easier in my opinion .
Now to get the smell of gear oil off of my hands :cry:
