Seal Number
Does anyone know the part number of the lip seal that goes inside the outer end of the trumpet housing of an 8N. Its the seal that the hub runs inside of.
Skip,Here are some Napa seal numbers that I have.
Outer Rear Wheel Seal 8N though S.N. 486752, # 24986
Outer Rear Wheel Seal 8N from S.N. 486753, # 27426
Inner rear Wheel Seal 8N # 19831
If you have an 8N with one seal per side ( no inner seal ) you can buy 2 seals for $12.99
[i:c78cb6a784]Axle Oil Seal-Outer - For tractor models 8N to SN# 486753. inside diameter 2 3/4 inch. Rear axle oil seals. Also comes as part of A8NN4248A Assembly. Packaged in qty of 2, price is for a pair. (Part No: A8NN4251A)[/i:c78cb6a784]
You would probably be happier to spend a few dollars more and get the set already pressed in the retainers . R & R'ing the seal from a retainers is a pain . $19.17
[i:c78cb6a784]Axle Outer Retainer - For model 8N to SN# number 486753. Rear Axle Outer Retainer. These retainers come with seals and gaskets. Order Qty of 1 for a set of 2. (Part No: A8NN4248A)[/i:c78cb6a784]
http://www.yesterdaystractors.com/c...mp;&md=8N&cat=Drive Train&r=mcats
