Prinscha
New User
hi can any one tell me if the cylinder block from a mm g1000 , 5star or a bigger engine will fit on a 206 block im i know the 220 block will fit but thinking about some thing bigger
(quoted from post at 01:32:23 06/14/23) hi can any one tell me if the cylinder block from a mm g1000 , 5star or a bigger engine will fit on a 206 block im i know the 220 block will fit but thinking about some thing bigger
The physical size of the blocks are bigger. I bought some "pulling pistons" from Welters for my 206 that were 302 pistons plus .180(if I remember correctly). This works out to a 226. You can find used 3 3/4 pistons and that would make a 220cid. I would think these pistons and hi-compression heads would give you an engine you would be happy with unless your wanting to pull 4mph and up. Just my 2 cents.
This post was edited by Dennis P on 06/14/2023 at 07:15 am.
