MM Twin City carb
Troyer
New User
Does anyone know if the Zenith U-6 carb is still available somewhere for a 21-32 or know of anyone that deals in old carburetors? This tractor has the air cleaner that hangs on the front manifold stud and is outside the hood. If the U-6 is no longer available what would be the replacement?
I appreciate the info. I'll make a note of it. Could you point me in a direction as to where to begin looking for one?
Let's try to find the Stromberg UT2. I failed to mention that the air cleaner is cast iron with FT cast into it, which may not make a difference which carb was used. And that was the first indication that the carb that was with the tractor may not be the right one. The air cleaner port and the intake on the carb are offset by an inch with carb being on low side and the air cleaner port on the upper and only 2 inches apart. Any connecting hose will kink with this set-up.
Have seen on Ebay. Is a brass carb and a poor one. similar ti a Model T one. Try old site www.strombergof.com
Strombergof.com is gone. Stan passed away two years ago.
I vote for the cast iron Schebler TTX-23 for your mid-late 1930 21-32 if you can't find a U-6.
The mismatched heights baffles me but I'm no expert.
