Water pump shaft play
Oliver.88.MM
New User
Hi. Putting together 605 power unit
How important is impeller shaft end play?
Put water pump on, engine spins fine , check it a
bunch as I am tightening nuts. When water
Pump is totally Tight engine still spins fine.
But shaft now wont push in the .025 it did
When it was not bolted to tractor.
Is this a problem? Thanks.
YES... You need to add shims between pump and front cover plate. But ,025 doesn't sound right. My books aren't at this location. Without any end play you will wear out the brass thrust collar.
MMDEL
