Drove the minni mo for the first time
So the minni mo runs good in first it takes a few seconds to stop hitting breaks and pulling cluch back and pull throttle all the way back put she runs good and sounds ever batter
Let me explain.....when in first gear the clutch won't release. You have to throttle way down and hold the brakes. Right before the tractor dies the clutch let's loose. I drove it around in 3rd and 4th no issues there. Is there an adjustment some where that will help this? It's fun loading it on a trailer! NOT!!
Yes there is clutch adjustment. Remove inspection plate, you may have to rotate things to see a pin you pull then turn plate in or out. I'm at work now or I would take a picture of the manual.
For loading it on a trailer I would never fully engage the clutch anyway. Just ease the lever forward till it starts moving, but don't snap it all the way in. Gives you a lot more control that way. Stay safe!!
According to the manual to adjust clutch you engage clutch then adjust counter clock wise, it would not move with clutch engaged. With out clutch engaged I moved it a notch counter clock wise and made it worse. So then I went back where it was then clock wise 2 notches. Clutch now releases within a second of pulling lever back. Maybe it was too tight to start with? It doesn't " click" when you engage it like manual says it should.
