Dose anyone have a picture of the pto lever
Here you go. Tractor needs a bath.
Lever slides a fork which is connected to a gear back and forth on pto shaft. Sliding gear into and out of splines engages and disengages pto. Can be serviced when top transmission cover removed.
Sometimes when you pull it out it comes out past the detents and it takes hard push to get it back in. When I had my transmission cover off I put a washer in there so it could not come out to far
