Anyone have any headlights for 445 / 5 Star and other parts?
Alan K
Im looking for maybe 3 headlights for a 445 / 5 Star. These are the teardrop style that are on a pipe similar to AC. Also looking for a working speedometer and tachometer for a 445. It is going on a working tractor so they dont have to be new, just work and look decent.
Tach drive was seized in side cover. Speedo fiber gear was bad in brake setup. Don't try to take apart without removing speedo gear or you WILL wreck it. It is NLA. I had a good one off 5 star.
I may be interested in one or two of those gears Del. Do you happen to have any spare speedometers or tachometers for the dash on the 445s?
All the gears for the drives I've seen are steel, or are you talking about the ones in the cluster. thanks chris
Alan; I may have, I have a pile of those dashes. I pick them up whenever I can. But I don't know if they are 445 or 5star. Never checked part numbers to know if they are the same. Also 445 utility would have much smaller tires than 445 row crop. Don't know at what part of the tractor they compensated for that.
MMDEL
I think the speedometers are the same number between them (10P1017) but the tach is different. I believe on the 445 / 4 Stars, the tachometer and speedometer both run from the left to the right. The 5 Stars the speedometer runs the same but the tach runs the opposite direction from right to left, so if both tach and speedometer run the same direction it should be 445 / 4 Star panel, opposite directions a 5 Star panel. Some numbers are different between the tach and speedometer on the 445 and 4 Stars. Will have to take another look in the parts book tomorrow. I will check my gears out and see what I need there. I would be interested in a speedometer and tachometer if you happen to have some that are decent looking and operate. Im just going to use the tractor in the field and would be nice to know what Im doing lol.
No. Custom made. stronger material. Only 3 left,and that's the end unless some one wants a 100 or more.
MMDEL
DEL, Are those gears the same between the 445 and 5 Star? If so I might be
interested in two of them. Will take a look at what I have today.
Yes, These are the composition gears at the axle for the speedometer, they are all the the same. the steel gears for the tach are different. I haven't had time yet to see what I have for speedos or tachs.
MMDEL
If they are the same in the 445 and 5 Stars, I would take two. Are you going to
the MM convention in Madison SD the end of this month?
MMDEL Did you happen to get a chance to look for the tachometer and speedometers yet?
Alan: Sorry i didn't get back to you sooner. I have a lot of tachs and speedos some may or may not work, but either the faces are all black and the numbers not visible, or the hands are broke off. Sorry I got your hopes up. I will save you 2 gears.
MMDEL
I still might be interested in them. I might be able to change some of the needles on them. I have a
couple here that are the same way. I will try and give you a call some time next week.
