hey IanC rvirgil
pa don
thanks for quick reply wanted to get runing as soon as posible ran all day with out a miss replaced coil with one off retired 4star coil was in both post note before had to let key off start prosition for it to start know itpops of before I can let go of key
Missing run circuit. Seen bad key stitch cause same. When start cct engaged power applied to starter and coil. When released still voltage at coil. Use testlight or ohmeter at coil. Supply should always be there when key on. If I see an electonic set up,hits garbage. Any I restore I go back to original. Been an electronic tech for over 40 years.
