TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
GVI shift lever
minniemo705
05-16-2018 19:49:33
does someone know why the shift lever would jump out of line and have half the ball on the bottom ground off? Well that happened. Was in first pushing a pile of manure up, put it in reverse then went to go back into first and it stayed in reverse in neutral, 2nd, and reverse. The other gears acted like it was in a higher gear than 5th and would kill motor. No neutral. Took the lever out and the ball on the bottom is shaved in half. Looked at my parts GVI and lined stuff up and everything works. But how did that jump out of line and what shaved that ball on the bottom of the lever? bottom line is does someone have a gear shift lever they'd be willing to part with? It was a rough night.
ChrisQ
05-16-2018 20:09:46
 Re: GVI shift lever in reply to minniemo705, 05-16-2018 19:49:33
I am parting out a G705 right now. I believe the shifter is the same. If you are interested, I can pull it off for you and see if it's any good.
mjohnson136
06-09-2018 12:17:03
 Re: GVI shift lever in reply to ChrisQ, 05-16-2018 20:09:46
ChrisQ im looking for some parts for GVI that should be the same as the G705 Do you still have parts?
Thanks Matt mjohnson@brownsburgfire.org
minniemo705
05-16-2018 21:19:23
Yes they are the same, I would like to get it if it's good. kiet4@3rivers.net Thanks
