Moline G1000
I currently have my G1000 in the shop, the Ampli-torque was slipping on the high side. Once I got it apart I found all the clutch disc and
plates had been hot and were warped. I ordered OEM replacement parts, My book list part # 10P993 for the fiber disc.
I received 4 OF part # 10P1459, and was told that is what is available. Now the question is the new disc only has about 1/2 the surface
area to pull on. I may pull this tractor at local pull. I have already fixed main clutch, and didn't want to put these in with less surface
area as well. Can someone offer any help on this. Thanks DAVID.
That part number is for the pto disc. The number that you need is 10p3736 or you could also try the old number 10p3464. These are for the 2 speed ampi-torc. Bob
