Wiring Harness M670 Diesel
J.A.R
In need of a wiring harness diagram a 670. My book don't show them labeled by color or for that matter even show them individually so I can't trace where they need to go. Also some one replaced factory switch with a general key switch eliminating the push button starter. I'm completely lost on this and can't find a harness for a diesel otherwise I'd just do that. Not sure if its charging either. If anyone has one it'd be much appreciated if they could help me out thanks a bunch.
I may be able to find one....E-mail is open, bottom right....classic view. I will need some more information from you.
Wayne
This is the only wiring diagram that I got and it's not for a super. If someone could scan a pic of a super diagram or point me in a direction on where I could buy a book that has them id be grateful.
Chris do the 900s and G1000s have the same harness I dug up a few older posts and they look similar but I can quite make out the numbers on most of the switches and such.
I haven't studied it much, but I would think the harness would be identical, aside from length of wires. The only exception really would be a 900 or 1000 is pressure lubed for the transmission and has an idiot light in the dash.
