Moline ZAU Parts
ABC1
I'm looking for a Drawbar and the Correct seat for a 49 ZAU. Currently have a pan seat on the spring arm but it seems much too low.
Where are you located? Those are larger, heavier parts. Shipping is not real cheap. I should probably have some of what you need.
OK, thanks for the info. Does anyone know where I can find one of these Seats relatively close to Connecticut so that shipping isn't prohibitive?
If you don't find one out east. You can take a nice drive out to Illinois. I have exactly everything you need.
MMDEL
OK, thanks. I wonder how much shipping
would be for the Seat assy. & Drawbar.
Would you have an idera of the weights?
The back rest is good. The seat back then had an air inflatable bladder. It is flat right now so don't know if it holds air or not. The new replacements are foam. I need your zip code to get a quote on freight. If you don't want to post it send me a e-mail or phone 815.456.2114
MMDEL
It's on a parts tractor sitting on the ground. I wanted to get it off and check condition before I priced it. I sort of miss read your original post, and thought you was wanting the seat support bar (going from the seat to the tractor). Am in the field now but will try to check this week.
MMDEL
