How much weight will three point lift?
vecair
Can't seem to find this info in our manual. Does anyone know how much weight the M602 three point will safely lift? We are using it with an arena spike drag that has concrete weights on it and I would say it weight about 400 lbs all up. Thanks for your help.
Cheers!
i hauled big round bales with a 302 with no problems lifting. Would get a little light on the front end tho. Probly weighed 1200 # or so. 670 was about the same. I would imagine a 602 would be about the same too.
Used to plow with a M 670 with an A frame on the 3 point hitch and semi mount plow. In tough going it would easily pick up the front end inspite of the weights hanging out front. It was mostly from the 3 point lifting (some also from pulling). The best way to put the front down gently was to back off the throttle. I wonder too how much it would lift.
