carvel minne farmer
good evening MNGB, you where right they are char-lynn valves on the m5. a couple of pics after I got the hyd tank, rotten hoses out and the mess cleaned up. if you remember the 2 brackets I found down in all the muck, well I found out why he didn't put them back!! they are a proper b***h to put in with the tank and everything out of the way. the valves where fopping all over with out them so installed the 1 good one on the right valve but now I need on for the left side. do you know where I would start looking for that bracket? will be checking with the hyd. shop i'm taking all the rotten hoses and lines to for replacement.
