minniemo705
So the radiator has to come out. The bottom and center are fine but the top of the tank springs one pin hole after another. What a pain. The wiring in the dash is also having issues- something is loose cause the lights were working then I touch something and out they go. Mess around and on they come and now they are out and I can't find the issue. It all started because something is wrong with the temp gauge- the old one and new one won't register and it was definitely warm enough to move the needle a little. But of course someone has been in there splicing some wires. The other gauges work, just not the temp. The diagram says there is a wire from oil gauge to temp gauge- not on mine. Instead I have on from low side of temp gauge to trans light. Going to have to disconnect everything in the dash and cut open the harness and start tracing. Electrical problems suck and the diagram in the book isn't that great.
