Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Oil leak on 206 engines any ideas?
03-08-2018 17:50:22
A 206 jet star/445 type engine. Leaking between the cylinder blocks (where they bolt on to the crankcase) but having trouble finding it. Any ideas thanks
03-08-2018 18:14:44
 Re: Oil leak on 206 engines any ideas? in reply to jocco, 03-08-2018 17:50:22
Is the leak on the right side near the oil tube?
It could also be one of the block gaskets.
I guess it could also be the gasket between the stud torque plate and one of the heads, and just run down and out from between the blocks.
FYI: the left side block bolts are in pockets just above the camshaft.
03-08-2018 18:09:24
Might look on the generator side, the oil pipe that goes up to the valves, the rubber bushing that seals the pipe might have cracked or misaligned and allows oil to follow the pipe down to between the cylinders. Good luck.
Ill John
03-09-2018 17:37:30
 Re: Oil leak on 206 engines any ideas? in reply to matthies, 03-08-2018 18:09:24
I'm guessing it's the oil tube on the left side of the engine
