Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Moline GVI
Mike Medlin
03-07-2018 14:22:04
Has anyone ever tried a turbo on a GVI diesel?
03-14-2018 00:57:04
 Re: Moline GVI in reply to Mike Medlin, 03-07-2018 14:22:04
Good info, but how much power are you trying to push when you start to blow rods out the block?
The GVI is factory 78HP at 1650RPm.
If you let it at 1900RPM, add a turbo, would you get to 110-120HP and still get a usable / reliable tractor?
03-17-2018 14:22:45
 Re: Moline GVI in reply to fdt860, 03-14-2018 00:57:04
705 has old style heads ,pump turned up ,timing advanced, all it is,, but tranny locked up an rods snapped,,son dishing .heard it rattle in shop .in 8ft two rods went threw side an pushed campout block at 3an 4 .. I run 504 puller it 600hp or better g1000 are better if u set them side by side u see lot heavier rods..if u want run boost pressure rods are your week link
03-11-2018 17:57:45
u find out the rods wont take it ,if u able to stall it or lock tranny up ,u blow rods right out block,,,u need at least g1000 rods in it ,they are thicker, it have a lot better response, but pistons pistons ,melt down from the heat, if u want run cutting edge of heat , there no steel ring in Minnie pistons ,we had several 504 with turboes , pretty snappy, ya I have one on direct inj, I have one its ind, inj.. it run wth 4020 turbo ,10 or 11 degrees on pump setting , but tranny broke , it blew rods right out side of the block,, easy ta do ,old style heads ,tighter chambers, if u want high rpms, change the heads, above 3000 rpms old heads wont flow air threw them , need change valves set up in heads u want rpms,, jus my two cents, I do it lol for fun ,,turbo on minnies are cool ,, jus cant get crazy ,or u be fixing it
03-08-2018 23:01:11
The here is a person on this forum that got a 705 turbo and G1000 turbo:
03-07-2018 17:35:20
Agreed the set up can not effectively move fuel and air to take advantage of a turbo.
03-07-2018 17:13:12
Be a total waste of time and money. MM used Lanova fuel system which will not respond to turbo like other higher rpm tractors.
carvel minne farmer
03-07-2018 15:33:16
mike I believe there is a you tube video on a turbo install on a gvi? or I may have seen a series of posts with pics of the build on this or mm forum? I will go hunting.
