3 point hitch 4 star
tpohl
We looking at a 4 star Moline. How do you get the 3 point hitch to work? I seen there are two levers underneath the seat beside the 3 levers on the side. Tractor runs good just can't figure out the 3 point hitch. Thanks
Of the three levers to the right of the seat, the outside one move to the rear of the tractor and 3pt should raise. Put the two levers under the seat in the middle of there range. Also you will need to remove the cover with the two levers and add atf/hytran to an inch of the cover if the levers don't do anything. chris
That lift is different than the ford or Ferguson, also. It is a draft control type lift. As stated below: all the way back, past a "bump" you feel when moving the lever is raise. When lift gets all the way up, lever will go back to "hold" position. Move it just below next bump you feel to lower. Then back to hold to stop lowering. All the way down on lever is"float". Between float and down is where lift is controlled by draft control. Takes some getting used to. Lift does not function like say a jubilee ford where position of lever on slide governs 3pt. height.
