Our GB propane we were using on an auger last fall when the starter started acting up and it wouldn't turn over right. I finally got around to pulling it off to find the end broken off where it is supposed to support the bendix gear bushing. I am replacing the bendix but I need the end piece that's broken. Anyone have one of these? I don't need a starter, this one turns it over great until this broke. It has numbers stamped into it "937354" but I'm not sure if there is any more ahead of these numbers as that's where it broke. Also, the piece that broke off must be down in the flywheel housing somewhere, I suppose I need to locate and remove that too.
