JoePro's floor jack attachment for spitting
Scout2008
Somebody asked for a picture of the piece JoePro had made to fit in his
floor jack that bolts to the rear end of the tractor when splitting. It
uses the 2 threaded holes where the drawbar front mount is. You just
remove the drawbar mount, bolt up the floor jack, and then your set to
raise and lower the rear end during splitting. It worked great on my
670.
thank you scout, I had asked you for the pictures , those are great and the square tubing riser from the plate to the channel iron looks to be about 6 to 8"?
Correct, I would say 6-7 inches. Went back together pretty well. And after running it a little shifts perfectly, and no slipping!
