Hi all,
I am seeking someone knowledgeable with M670 Super steering systems. I understand this is a hydrostatic system with a Saginaw hydro motor. My hydro motor is leaking fluid through the steering column. The steering shaft is wore down on the end and the torsional shaft is showing through. Also the locking pin between the outer input shaft and torsional shaft has fluid leaking out. I understand parts to rebuild are VERY uncommon now. Does anyone have part numbers or anything that can help me to convert this steering system to something updated (charlynn)?
Thanks ahead of time, Colin.
