Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
1937 Z rear
Jerry Grant
11-25-2017 18:09:28
I am starting a full ground up restoration project of a 1937 ZTU on rubber. I was wondering if any one has a great idea how to get the rear steel rims off the cast hubs? With some banging and pounding I was able to get the rims off the front cast hubs. However, on the rear, the studs came out with the nuts pretty easy but there is no evidence that these rear rims have ever been off the hubs and I know the tractor has been setting for many years. I was thinking (dangerous I know) if I got the hub and rim assembly off the axles, laid them down flat on their back (with the U bolt part up) and then tried to drive the cast hubs down out of the steel rims. I know these rear cast hubs are often broken but these are not so I do not want to damage them. Thanks for any suggestions. Hope everyone had a great Thanksgiving.
11-30-2017 09:07:12
 Re: 1937 Z rear in reply to Jerry Grant, 11-25-2017 18:09:28
Try the other suggestions first. If all else fails, get the tire off, take a sawsall or a cutoff wheel and cut through the rim at one point to take the tension/pressure off.
If the rim is worth saving, you can weld it back together.
11-26-2017 17:57:12
Had that problem n my UB. Took hub off axle and beat wheel center out of wheel.
Roger H MI
11-26-2017 13:10:23
Been there done that, The bigger the hammer the better.
11-26-2017 10:22:06
That's the way to do it.
11-26-2017 05:41:22
Had a 39 U with similar problem. I used hydraulic jacks from chassis to rim amd pushed from behind. Kept turning wheel to different places on rim.
