This is the thing I dragged here last month. It had no motor Just empty crankcase and pile of parts in pails and newspaper. Not sure why previous owner went to all the work of
cleaning all components. All ended up as junk. Pistons were 20 over and blocks had 60 over wear. Had a couple parts units and most NOS parts.Had to get 1 ring set and couple of mains.
Original crank and cam were in special made wooden crates but were also badly worn. (junk) The puzzle is coming together. Tomorrow chassis gets a cleaning before further assembly.
M5 with adjustable axles and 3 point uncommon here. Only one I have ever seen. Have 3 or 4 others but all standards.
Keeping the old Bosch pump for now as it matches the serial numbers for first generation. If it doesn't pan out the Roosa setup will go on if I find a pump
