Inverted flare washer/seal
matthies
I remember seeing an insert to seal an inverted flare fitting. A hydraulic line on my 4 Star is leaking and the nut is bottomed out, this seal/washer/shim would take care of this I'm sure just can't remember where I have seen them. thanks chris
(quoted from post at 10:08:21 10/16/17) I remember seeing an insert to seal an inverted flare fitting. A hydraulic line on my 4 Star is leaking and the nut is bottomed out, this seal/washer/shim would take care of this I'm sure just can't remember where I have seen them. thanks chris
I have used copper brake line washers for this purpose.
